IMC 4500 black fade
  • lhmy
    • Oct 2023
    • 33
    #16
    Originally posted by hoanganh836618
    I almost never have to do it again... in my case, if the toner fades, it's mainly due to the process of changing from genuine toner to non-genuine toner. When the printout fades, I often go to system sp code 3200 to check the parameters. Normally the fading index of colors is about 10.0 to 13.5 or more. after I did the process as I said and did 1-2 test prints it dropped between 7.0 - 9.5. Honestly I don't know what the code 3200 is...
    As i can see the sp 3200 is the toner density and it shown in percent and at sp3201 we can see the upper and lower TC
    so can i conclude that if its higher than 9% then it requires more toner to be added in the development?
