White line
  • YHEL23
    • Nov 2008
    • 146
    White line
    Good day to all,
    Replaced Drum,Cleaning Blade.Charge roller, Transfer Belt.
    Cleaned all optic and LD unit.
    The Machine copy 200k any more idea on this, Please see the attach file
    for more info.
    Thanks in advance
    Yhel
    DYNAMIC OFFICE SOLUTIONS
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    A full coverage print with toner missing in a consistent ribbed pattern?
    Check out the dev roller / doctor blade / unit.
    • YHEL23
      • Nov 2008
      • 146
      I try to swap the PCU. I take the PCU to other machine. Still the same!!!
      • Cipher
        • May 2006
        • 1309
        What's the model?
        • YHEL23
          • Nov 2008
          • 146
          What's the model?
          Sorry... Its MP4000
          Thanks Clipher
          • Cipher
            • May 2006
            • 1309
            So you have tried a completely different PCDU or have you only tried the same PCDU in a different MP4000?
            • YHEL23
              • Nov 2008
              • 146
              I installed the different PCDU to the machine that having white line still the same.
              • Cipher
                • May 2006
                • 1309
                Hmmm that's pretty weird then.
                As that pattern on your sample print is a dead ringer for how the surface of the dev roller looks.
                I can't think of any other roller that would produce / leave a mark such as that one.
                • YHEL23
                  • Nov 2008
                  • 146
                  As that pattern on your sample print is definely a dead ringer for the surface of the dev roller.
                  That what i think also....But after i installed the different PDCU still the same.its possible LD unit can cause this problem???? I will try to replace the LD unit and i let you know.
                  thanks again clipher have a nice day.....
                  yhel
                  • Fearless V K
                    • 620
                    Is the pattern on the internal test prints?
                    Don't take that toner with me!
                    • YHEL23
                      • Nov 2008
                      • 146
                      Text copy can't see the white line, only if my client photocopy the dark background.that is sky shoot.
                      • Fearless V K
                        • 620
                        Generate the internal test pattern with dark black bands (can't remember the name of it) and see if the problem is still there. At least that will isolate the optics. Also make sure the white plate is clean on the scanner.
                        • YHEL23
                          • Nov 2008
                          • 146
                          I will try and let you know
                          Thanks friend,
                          • KopyKat
                            Nurse Ratched of Repair
                            • Nov 2008
                            • 366
                            This may sound too simple....Are you saying that this ONLY shows up on sky shots? Or does it show up with the cover down and large solids? The reason I ask this is that you say it does not show on text. I have seen this Exact pattern on sky shots when there is a florescent lamp above the copier. I may be just talking out of my butt again.
                            sigpic
                            Relax! This firmware injection won't hurt...but it will take 45 minutes.
                            • YHEL23
                              • Nov 2008
                              • 146
                              its show if photocopy a dark background and cover is down. I try to print from computer with a large solid its fine. So now i will focus to the optic section.Still doing the troubleshooting.....
