LF225 Smart Card question
  • rthonpm
    • Aug 2007
    • 2854
    This is the first one of these machines I've seen. Not much to it, but when the customer changed the toner for the first time and used the Smart Card bundled with the AIO the display says that the card has expired. It doesn't seem like the card would have a 'use by' date so is it just a bad card?
    As a workaround I have set the machine to Without Toner Maintenance, but this could eventually cause an issue. Do I just need to order a new Smart Card or is there a bigger issue at play? I saw a bulletin regarding clearing consumable counters and I have downloaded the firmware but the machine is a good 85 miles away so I want to make sure I have the right tools to fix it...
  • copytec
    Do not excite,
    Order new cartrige and you have a new card.
    When time is come, back set for Toner Management to WITH.
    Folowing procedure on display. Be carfully, only ONE tray you have.
