RICOH 2238
  • hodgiepodgie
    • Jul 2008
    • 284
    RICOH 2238
    Has anyone any ideas first why i would be getting light copies off glass on ricoh 2238 black new dev new pcu.seems to be common on all my 2238 mach we bought recond.print jobs are fine.
  • aabarnes1
    • Mar 2009
    • 620
    Had same problem 2 weeks ago, replaced k dev, pcu to no avail. Eventually we did the firmware upgrade and all those laser pitch adjustments and it's been fine since, hope this helps
    Grant me the serenity to accept the things I cannot change.
    • hodgiepodgie
      • Jul 2008
      • 284
      hmmm
      well these were refurbs that firmware should have been done so w/o access to ricoh will have to guess as to if he put latest firmware on it thnx
      • dckm
        • 79
        Seems to me, that if the machine is not in text mode, it is very light. I think there is something in the gooses guide, or tech bulletin somewhere.
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          Did you clean the optics?
          • Jomama46
            • 2900
            What a trusting soul.
            After you clean the optics, run the ACC. User Tools >Maint>ACC. This will optimize the optics to the engine.
            Engine FW Engine Q; sys Q
            sigpic
            A+; Network +; PDI+
            • sakura
              • 132
              Based on information provided I can make an assumption that possibly "white color registration plate" could be dirty. First of all check it out is it OK (not dirty) cs it can make copies lighter due to wrong "TRUE WHITE" registration.
