Ricoh MP C2500 SC491 code
  • RicohFaults
    • May 2025
    Can any1 inform me what this code is please - and any info on fixes?
    Cheers.
  • Philinghorn
    • Sep 2008
    • 29
    SC491 is High Voltage Power - Drum/Dev bias output error
    Sorry not had a machine with this fault, but check pcu's & paper transfer unit
    Good Luck
    • RicohFaults
      Good Luck
      Many thanks
      • Ricohlovers
        • May 2009
        • 59
        Hi,
        Note the following. Thanks
        No. Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
        High voltage power: Drum/ development bias output error
        An error signal is detected for 0.2 seconds when charging the drum or
        development.
        􀂃 High voltage leak
        􀂃 Broken harness
        􀂃 Defective drum unit or development unit
        􀂃 Defective high voltage supply unit
        491 D
        1. Check or replace the harness.
        2. Replace the drum unit or paper transfer unit.
        3. Replace the high voltage supply unit.
