SPC811DN
  • countrytech
    • Mar 2009
    • 68
    SPC811DN
    Hi,
    Does anyone know if it is possible to use the black drums for colour in the SPC811DN printers.
  • E Winter
    you mean the black drum unit for the copier or the complete spc811 black pcu?
    You can swap the drum units from bk to col easily - just take care to modify the connector at the back of the unit (just compare them) and keep the original front cap in use.
    • countrytech
      • Mar 2009
      • 68
      G'day
      Thanks for that information. I was just looking at using the black drums for colour, not the complete pcu. From what I can read, they may be the same as the mpc 4500. Do you know if that is correct?
      • E Winter
        Yeah you can use the B223-2042 (black drum unit) for all colors (with the modifications mentioned above).
        Using the SPC black PCU for CMY doesn't make much sense because this is an assy including the black development unit.
        • imaginemoko
          unTrusted Tech
          • Jan 2008
          • 289
          if its same as MP C3500 or 4500 yes just take the old connector of any CYM to put on new Black OPC...
          fix the customer first then fix the machine... its simple and makes life more easy.
          • Froota
            Field service tech.
            • 129
            Originally posted by countrytech
            Hi,
            Black pcu's are a lot cheaper than the colors.....so good choice!
            • tcs04
              FORMER Techie
              • 1183
              We believe Ricoh (Europe?) are now applying superglue to the connectors on the black units to prevent them being used for the colour stations! (The locating pin breaks off when removing the connector!). This applies for the MPC4500, not sure about the printers. I've seen a post suggesting the printer units may be MUCH cheaper.
              • jakpong
                You can extualy use SPC811DN PCU put into MPC3500/4500 by cutting the connector shap to the same as MPC PCU, swop the TD sensor use two small flat screw driver flip the TD sensor out and be careful then use double sided tape, swop cover or cut out the difference, less cost and times.
                • E Winter
                  I never swapped the whole connector With a little practise it's way more faster to handle if cut away the edge of the existing connector and peel of the little metal stick what is suppose to avoid this action
                  You can also flip the td sensor pcbc out of it's housing - it will click into another housing so no need to use tape. This is easy but I'd recommend to practise this on the printer PCU TD sensor first because that's for the garbage anyway.
