MPc 2050 Scan to media
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Did you guys know you can scan to a pen-drive without the optional, just go into user tools scanner functions and activate the function, then insert the media into the most front USB slot on the left hand side of your machine " media must be formatted in FAT 16 or 32", then press scanner key and choose your option. thats it work fine
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 365
    Good info! Thanks!!
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • Jomama46
      • 2900
      Thanks iMind, I gotta try that!
      sigpic
      A+; Network +; PDI+
      • mrwho
        Major Asshole!
        • 4299
        Doesn't work for me. Enabled the SP, rebooted the machine. Now, when I plug a USB pen (4Gb formated FAT32), it tells me an unsupported device was connected to the USB port.
        Mascan42
        Ibid
        • iMind
          • Mar 2008
          • 1116
          Sorry I didn t mention is, but its in the manual, the machine only supports up to 2Gb.
          • Jomama46
            • 2900
            I see a function in SP (1013) but not in UserTools. Did you mean SP mode?
            sigpic
            A+; Network +; PDI+
            • mrwho
              Major Asshole!
              • 4299
              I saw that one, but thought it was only relevant with SD cards.
              Thanks! Will buy a cheapo 1Gb pen to try it out!
              Will post results later!
              Mascan42
              Ibid
              • mrwho
                Major Asshole!
                • 4299
                SP Mode, Scanner SP
                Mascan42
                Ibid
                • iMind
                  • Mar 2008
                  • 1116
                  Scanner SP Mode
                  1013 [Multimedia Function Setting] *CTL [0 or 1 / 0 / - ]
                  0: OFF, 1: ON
                  1013 1 On or off multimedia function
                  • mrwho
                    Major Asshole!
                    • 4299
                    It works.
                    Did it with a colleague's 512Mb pendrive formated with FAT32.
                    Thanks again for the tip!
                    Mascan42
                    Ibid
                    • iMind
                      • Mar 2008
                      • 1116
                      just go into user tools scanner functions and activate the function, hehehe, this must have been a Jack Daniels night... sorry
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Just tried it on my demoroom MPC4000.
                        Worked like a champ!
                        Thankz!
                        • Jomama46
                          • 2900
                          Tried it on a C2050spf with a 2G pen drive. Fast effective and auto disconnect.
                          Thanks again, iMind.
                          sigpic
                          A+; Network +; PDI+
                          • Froota
                            Field service tech.
                            • 129
                            fantastic!
                            Nice information,
                            thx,
                            Froota
