Savin 9920DP printing problem
  • mlsptr
    • May 2025
    Someone was playing around with the printer setup on our machine and now it just displays "initializing". Is there a way to bypass this and reset the printer functions?
    Any help will be be greatly appreciated.
    Peter
  • Jomama46
    • 2900
    There is a menu reset feature in UserTools, I think in UT>Printer features.
    sigpic
    A+; Network +; PDI+
    • mlsptr
      Yes, I have tried menu reset from UT>System but it doesn't clear the printer configuration. I need to find a way to access the printer UT because they don't appear as the printer is "initializing". I was hoping to find a way to reboot the machine to the factory defaults.
      • Jomama46
        • 2900
        If you cant reach the ut settings you must remove and reinsert the SIMMS on the controller and any other connection. If this doesnt resolve it, replace the controller.
        I would suggest 5-801 memory clear but I dont think that includes the printer. But if you decide to try that be sure and print out an smc list 5-992 first.
        sigpic
        A+; Network +; PDI+
        • mlsptr
          Thanks for the reply. Where are the SIMMS located on this machine?
          • Jomama46
            • 2900
            On the controller board
            sigpic
            A+; Network +; PDI+
