NetBIOS name is in use already (108) error msg
+ More Options
Posts
  • scoobysteve
    • Jun 2008
    • 163
    Hi All,
    I've got a client who has multiple Ricoh machines and lately they've reported that two of their machines, (both AF3245C) are giving a netbios name in use error. All other models are ok. The clients change the hostname of their copiers to include internal location and model number of the copier.
    We have changed the Hostname and Machine Name and the SMB computer name of one of the AF3245C to something random (mixtures of numbers and characters) however we still continue to get this netBIOS problem.
    Can anyone suggests where we may have missed?
    also would a NCS clear default netBIOS back to factory? thanks.
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 366
    Originally posted by scoobysteve
    Hi All,
    Yes an NCS clears everything on the NIC including IP Addy...print yourself a config page first.
    Have the machines been rebooted after the name changes?
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • scoobysteve
      • Jun 2008
      • 163
      Hi,
      thanks for the help... but i have new news.
      the next morning after my visit, i received several more calls from the same organisations saying that their MFDs were also giving netbios conflict errors. the mfds were different models to the AF3245C.
      I think the organisation may have a netbios DOS attack which i believe they are now looking into.
      thanks again for the help.
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        ip conflicts its a network problem not on the machine.
        fix the customer first then fix the machine... its simple and makes life more easy.
        • Fearless V K
          • 620
          I agree, network problem. Ricohs have virtually bulletproof network hardware. Haven't replaced any in 5 years.
          Don't take that toner with me!
          • scoobysteve
            • Jun 2008
            • 163
            Hi All,
            I know the Ricoh's hardly ever have any NIC hardware problems however, we all know that we still have to try and sort/troubleshoot the problem for the customer first (even though they have their own IT). Otherwise, these customer just dont come back when they need a couple more - and trust me, even though it is not our fault or a fault of the machine, they will say that the machine and the service provider was not doing their job.
            • stephend
              Senior Technician
              • 306
              Hi All,
              You are right my friend...doesn't matter what you will do during the service contract....You can be there every day for courtesy visits...at first problem customers will blade the machine and tech/ service organization...If we want to keep them for another contract we must do extra work and troubleshoot in areas not related with the machine. I have two customers with the same problems and it's an ongoing problem since the machines was installed years ago....All the machines will pop up the same Netbios msg 4 or 5 times a year and the customer is angry every time.
              They damaged a NIC board on a 2060...the RJ45 connector was cracked and they was blaming the "damn Ricoh machine"....In those situations just more Advil or more beer....I prefer the liquid anti depressive solution.
              • scoobysteve
                • Jun 2008
                • 163
                Hi All,
                Just got a message back from the Client IT and it seems that their WINS database was corrupt.
                Funny that because i had asked them to look into their WINS database.
                Supposedly everything is ok at the moment.
                • opiumdot
                  Re: NetBIOS name is in use already (108) error msg
                  We have a Ricoh Aficio MP 4000. After a scheduled power outage I got this same error after powering up all our servers/printers/etc. I finally resolved it after many trials of changing the copier name (even though it doesn't share a name with any other device), restarting the copier, deleting the WINS active registration for it on our WINS server, etc. WHAT WORKED: I just unplugged the network cable from the back and went into the interface options/ip address (don't change it) just exit out then it should refresh the network settings (a few seconds pause where the buttons gray out) and clear the error. Then plug the network cable back in and it was good to go with no more error!
                  This worked for ours hopefully it will work for yours too!
                  • pepper38_cnd
                    Field Service Manager
                    • Aug 2005
                    • 1075
                    I have seen this exact issue on my KonicaMinolta machines at one customers, and yes it is their system that is creating the issue. The work arround I found was to disconnect the network cable and reboot the machine , once fully rebooted plug in the network cable and all is well. Whenever this problem reoccures follow the same proceedure.
                    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                    Now into Ip TV KODI Boxes
                    • SysAdmin21601
                      Hi All,
                      ....also would a NCS clear default netBIOS back to factory? thanks.
                      Had same issue with SAVIN MP3002. Coming out of Power Save would beep incessantly and then throw NetBIOS error message. Clearing the NCS worked for us.
                      Thanks for the tip.
                      John
                      • peterxu256
                        • Jul 2014
                        • 110
                        Thanks for the tip.
                        John
                        Yes, It just happened to me yesterday, I instantly do myself by clearing NCS without checking the post. Although the error message gone, printing speed slow from customer's window application like Ms Word, However the Test Page printing fast as usual, it took me another couples figured out the problem of printing speed. Reinstalled printing driving, problem remains,( it is true customers who don't care it is Network IT Guy's job or Machine service technician's work), late I happened to me installing the driver in old fashion, Choice 1, local printer, create a TCP/IP port etc.. it sounds working in normal under Wins Xp condition ,In my production mode, I just replaced the machine for old one using same IP address. If we had known the concept of NeyBIOS very well, we did not have to spend additional time to solve the problem in whole.
                        • hdmr
                          Helpdesk Engineer
                          • Feb 2013
                          • 51
                          I know its a old thread but seen this creeping in a couple of times over the last few weeks.
                          What is the process of clearing the NCS and what information is changed/lost?
                          Work from a helpdesk so don't want to perform this and lose information I don't have.
