2232c sc 391-02
  • ash_572
    • Oct 2008
    • 523
    2232c sc 391-02
    i have replaced the yellow pcu and cleaned all the contacts on all pcu's. have also cleaned the rear conectors on the back of the machine. when i did replace the yellow pcu the fault transfered onto the magenta pcu.
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Air pump
    Hi
    Not had this one myself before, but the manual says 'Airpump faulty'. Seems the Mag and Ylw are linked. Hope this helps
    • ash_572
      • Oct 2008
      • 523
      its got nothing to do with air pump.
      charge ac power output error.
      av only just fixed it aswell. replaced the power pack board which is on the lower back of the machine. looks like someone kicked the machine and damaged the board not that it looks damaged.
      • CableGuy
        • Oct 2008
        • 417
        You're quite right, seems I should have gone to spec savers......
        I'll just go sit in the corner.....
