aficio 250H
  • DINGO
    • 661
    aficio 250H
    Hy
    can somebodoy help me, because y have a aficio 250 thats gives me a sc322??
    wath y can do?
    y aperciate the help, because y work more whit sharp, and y don,t any manual of ricoh.
    Other thing more, the copyer have the pcu drum ligthing, is possible to delete this mesage with some code?
    thanks in advance.
  • tcs04
    FORMER Techie
    • 1183
    Without checking the manual, SC322 = polygon mirror motor. You may hear the motor whistling before the code appears. Also, check / change the fan at the rear left corner of the unit as these used to fail causing the motor to overheat.
    • DINGO
      • 661
      re
      thanks for help
