Mpc 3000 sc code cancel?
  • mikadonovan
    • May 2008
    • 2931
    I have a mpc 3000 that had a finisher malfunction, SC 792. The finisher has been removed from the machine, but the sc alarm code still shows on the LCD. I've tried a reboot, sc code clear with no luck. How the heck do I get rid of it? I've scanned through the 5XXX sp's and tried a few different things with no luck. I'm probably having a brain fart and don't even know it.
    NEVER ASSUME ANYTHING
  • rthonpm
    • Aug 2007
    • 2852
    You have to remove the bridge unit to clear this. If a bridge is installed then the machine starts to look for a finisher, when there's no reply from one it codes out. No other way to clear it that I know of...
    • mikadonovan
      • May 2008
      • 2931
      Super advice. That took care of it. Thanks.
