print errors in cl 7000
  • DINGO
    • 661
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Sounds normal, PDF by any chance?
    Bitmap's are large uncompressed images and they will take a age to spool and print.
    Check the print driver is the latest version as there are bug fixes.
    If it is a PDF try recreating the customers file from within Acrobat std/pro embedding the fonts and using a older PDF version (1.4 or 1.5).
    I've found alot of these thrid party PDF writers and pluggins they use can be flakey and cause these kind of issues.
    Finally if all else fails install the PS3 or PCL5c driver along side the RPCS and do some test printing.
    • Froota
      Field service tech.
      • 129
      Yes,
      Use the pcl5c driver from the website.
      (http://www.ricoh-support.com/enduser...0/cl7000en.htm)
      Better results, certainly for color prints.
      good luck!
      • DINGO
        • 661
        re
        thanks friends
        y go use the pcl5 drives.
        in fact this errors ocors more in word documents.
        thanks again.
        • DINGO
          • 661
          re
          Hi
          the pcl5 drive doesn't do 1200x1200 dpi like rcps??
