Let me run this by you guys because I'm stumped. This is the big finisher that staples 100 sheets and it's on an Mpc6000. This machine has run flawless for a year now but all of sudden it's started to jam in the finisher.
It only jams on legal and letter short ways when you stapled. 8.5x11 out of tray 1 and Lct staple perfect as well as 11x17. I have tried using differnet paper trays but didn't make a difference.
I believe that letter long ways and legal takes a different path through the finisher to get to the staple tray. There is a gate that supposed to open to send those sized down there. So far I replaced the finisher main board, reflashed firmware, replaced the moter that drives that gate(no solenoids there) and the sensor on that moter.
None of that worked however I discovered that if I take a pen and manuelly hold that gate open then the legal paper works like it's supposed to and staples. If I don't hold it open the paper gets about 3/4 of the way into the staple tray and jams.
Any ideas???
Any ideas???
