I replaced the photo conductor on the afificio 1515 but now when i switch it on it display systems error 392 how do i resolve this
Afificio 1515 photoconductor problem error 392
Did you plug the new PCU in? (To the left of the dev unit?)
The machine should detect the new pcu and then initialise the dev. If this fails you will get SC392.
If either of these is the case REMOVE THE TONER then reboot the machine and see if the fault clears. If not try SP2214 to manually initialise the dev.
If this works check the readings with SP2221.
Only refit the toner when you get normal readings for Vsg Vsp VT etc. -
kirri72
Yes i removed both plastic strips,
I also pluged in the new PCU
i'll try to manually initialize the dev unit.
Thanks for the quick response and info too
Regards.
