Ricoh 2238c waste toner problem
  • JOEBOOROCKSYOU
    • Jan 2008
    • 85
    unit says "waste toner almost full" but i emptied the bottle,
    any suggestions...
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    There is a simple sensor with a feeler arm above the waste toner bottle at the front.
    Reseat the waste toner bottle / check the spring mech that pushes the waste toner bottle up against the sensor / check the sensor it's not dirty or damaged.
    • KopyKat
      Nurse Ratched of Repair
      • Nov 2008
      • 365
      I'm with Cipher on this. Here's some added info:
      waste toner full will not clear - check waste sensor with SP 5-803-13 bit 3 (0 not full, 1 full)
      sigpic
      Relax! This firmware injection won't hurt...but it will take 45 minutes.
