If you are asking how to set the developer in an Aficio 1060, use 2-801. It will ask for a -lot#-, and this is the number that is on the top of the developer bag. You do not have to use this, and I always do, but in case there is a bad batch of developer sent out, you'll be able to know which machines they were installed in with this number.
After you enter the lot#, you can execute the developer setup. It takes 1-2 minutes, and it will finish.
Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
