main power button on op panel won't come on
  • copierfixer
    • 31
    Hey everyone....
    I am working on a ricoh mpc4500 (there may be other models with this problem)
    when the copier goes into sleep mode you can not touch the main power switch on the op panel and get the machine to wake up. Only if you put something in the df, open/close the df or print to it will it wake up. As to date we have replaced the entire op panel and controller. Anyone else ran across this problem? Don't think it has anything to do with the current bullet on the touch panel as when I do a calibration test all works fine.
    .....Help!!!!!
    rb
  • KopyKat
    Nurse Ratched of Repair
    • Nov 2008
    • 366
    Originally posted by copierfixer
    Hey everyone....
    .....Help!!!!!
    rb
    Does it wake up if you press the Energy Saver button? I'm thinking this is normal operation. The machine is still on, just sleeping....waiting for some action like setting a document. Pressing the Main Power button would be like you wanted to turn it off.
    Maybe I'm crazy...I'll check some of mine to see.
    sigpic
    Relax! This firmware injection won't hurt...but it will take 45 minutes.
    • Vulkor
      • Jun 2009
      • 946
      Agree with Kat, most of these don't come out of Energy Saver by hitting the Green Start Button. You have to raise the Lid/ADF or sit paper in the ADF Feed,
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        i agree also.. i guess its just normal... i'll verify this one also and play at user tools...
        fix the customer first then fix the machine... its simple and makes life more easy.
        • KopyKat
          • Nov 2008
          • 366
          From the SM: Section 6.11.7 Energy Saver Modes
          Return to stand-by mode
          The machine returns to stand-by mode if one of the following is done:
          • The Clear Mode/Energy Saver Mode key is pressed
          • Any key on the operation panel or touch panel screen is pressed
          • An original is placed in the ADF
          • The ADF is lifted
          The return time from the panel off mode is less than 30 seconds.
          Nothing about the main power switch. Your machine is behaving normally. You have been chasing a ghost.
          sigpic
          • copierfixer
            • 31
            NO-NO-NO I think we are misunderstanding
            Everyone I am saying this.....If the machine goes into sleep mode or if you are (properly) shutting the machine down You can not touch the main power button (upper right corner of op panel) and get it to respond. Holding it for 3 sec to shut the machine down or to bring it back up it will not respond at all. Calibration shows ALL other op panel keys working fine. I am currently at another machine of the same model and I can hold the main power button down and fire the machine up and then bring it back to stand by mode (green light flashing)
            Hope this clears it up as to what I was posting
            rb
            • KopyKat
              • Nov 2008
              • 366
              rb
              Communication errors happen a lot here. I understand now what you mean.
              I would reload all the firmware and check all the connections from the ops panel back to the controller.
              sigpic
              • mikadonovan
                • May 2008
                • 2931
                After rereading your post I see that you have replaced the entire op panel. I suppose it is possible that the power switch on the OP-R PCB on this one could be bad also. A shot in the dark.
                OP-R PCB part # B2381470
                NEVER ASSUME ANYTHING
                • Captain Scott
                  • Dec 2008
                  • 166
                  What is the auto off setting set to?
                  • copierfixer
                    • 31
                    found the problem
                    pinched wire and a broken wire in the harness of op panel. repaired broken wire and machine now shuts off when you push the button.
                    Thanks everyone!!!!
                    rb
