Gest. Dsm622 SC819
  • MHeon71
    • Oct 2008
    • 489
    Gest. Dsm622 SC819
    They tend to get SC819 code often enough when they print. I have seen SC990 pop up once also. I am not to familiar with Gesteners, but I have done some research and it looks like I have to flash the machine. How do I flash the print controller? I could not find that and where can I get the firmware?
  • RicohTech_TurksCaicos
    • Aug 2008
    • 55
    If this machine has the print scanner option unit then I would think there is something wrong with HDD and or memory
    • TonerMunkeh
      Professional Moron
      • 3865
      HDD's gone. 40GB 2.5"IDE sat on the controller board.
      Hit it.
      • imaginemoko
        unTrusted Tech
        • Jan 2008
        • 289
        try to reformat the HDD... if no avail... try to replace it sir... as mention above...
        fix the customer first then fix the machine... its simple and makes life more easy.
        • MHeon71
          • Oct 2008
          • 489
          I will try your suggestions and report back to you guys.
          • MHeon71
            • Oct 2008
            • 489
            I have replaced the HD and so far so good. Thanks for the help.
