Gestetner dsm-620d getting sc-302 codes
  • axyun
    • Aug 2007
    • 1323
    Customer called with sc-302 codes which I looked up and it is a charge roller or HVT code. I believe this is the equivalent of the Ricoh Aficio 2020D. WOuld cleaning charge roller usually take care of this or is changing recommended or is there something ekse i should be looking into. Does the roller slip out of posion etc? Frank/ ActionPhotocopy
  • gernah
    • Jun 2009
    • 57
    Charge roller leak
    Dear sir this is the answer of your problem sc 302,in the manual mention the charge roller and high voltage board is defective but to my openion you must change the charge roller and drum and check also then life span of your consumables maybe its over already thats why its come the error,I will explain to you why sc302 is come out because the sid by side of your drum is grounded already when the charge is applied its leaking.
    • ash_572
      • Oct 2008
      • 523
      ive also posted the same problem. think the machine needs a PM.
      • axyun
        • Aug 2007
        • 1323
        Thanks much. That is what Ill do Frank
