Ricoh 4410 SC322
  • pals80
    technician
    • Jun 2009
    • 18
    Ricoh 4410 SC322
    When I turn on the fax it comes up saying replace toner. I opened the front door close it, then it goes into SC322 ( laser code). I replaced the FCU pwb and the laser unit, (both listed in the service manual) still the same. I manually added some toner to the drum unit. Still no change. I cheated the side door to make sure the drum was turning. HELP!
  • jprecht
    • Dec 2008
    • 104
    sc 322
    wow, not familiar with this box but these ricoh fax'es are fairly bullet proof. is there a "laser shutter" that is not fully open? have seen this several x on other bxs. did you change out the toner cart with an "oem" cart? adding toner directly to drum cart will NOT eliminate this message. suggest you chng tn cart first then see if you get 322 code. try this and will go further!!
    gluck jp
    also cpy cnt???
    IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
    THAN TO SPEAK AND REMOVE ALL DOUBT
    • CANCOUNTRY TECH
      • Aug 2008
      • 114
      ive had this a couple of times try replacing the toner cartridge this sc322 occurs sometimes when theres a cartridge change.
      • Eric1968
        • 2458
        I think you have 2 problems : the SC322 and the replace toner message. I would replace the PCU unit. I have a lot of these faxes in service and sometimes the PCU-Unit gets overtoned.
        • pals80
          technician
          • Jun 2009
          • 18
          finally fixed
          sometimes it is the obvious. The toner cartridge was defective. After replacing it no more Sc322... Thanks for the help
