machine jams after 3-4 copies. read the manual, cleaned the charge roller and vac'd out the pcu. there is also an RTB on this sc code which i have already done. machine had done nearly 200k. might refurbish the pcu and also there is a possibility that it might be the supply voltage board.
anyone else had this problem before?
