ok have error sc990.have replaced drum unit ,hdd,what is the firmware upgrade for that error code believe it is up to or past that upgrade number. so have done everyting i can thnk of to no avail still getting error sc 990.
ricoh 1035/45
SC990 is a software performance error and can happen when a reading goes "out of spec". It is possible for the laser diodes to get dirty if the machine has been puffing toner, this will cause the laser power to increase to the maximum and produce both SC990 and SC322 (?)
There are other things, which can cause the same code, and I'm sure these will be mentioned in due course!
If he machine runs dirty around the toner hopper / dev unit and the front of the laser unit is dirty, change the filters between the toner hopper / dev unit / PCU to ensure a good seal and prevent the laser diode board becoming covered in toner before changing the laser diode board. -
Sir regarding with your problem no need to upgrade the firmware if you change already the drum unit you follow the procedure on how to initialized the id,change the default setting of your charging but you must clean the id sensor before you intialized your problem its solve okComment
ok
Well i have done all the above and still have sc 990.now i have not checked door swtchs but yes me thnks thats the 2045.also r hdd big mistake customer threw old one out.cleaned laser unit r r drum unit cleaned all toner. So should i replace boards starting with i,o. Board?also have not done firmware upgrade but was done last year that was supposed to stop sc990,did not stop it.so my only solution is to try boards.what do you guys yhnk? Oh and by the way customer is pissed,so am i we inherited this from another competitor,good reason to do pre cheks before oking for m.a. Anyway im at the end of my rope with this one.Comment
Replacing the LD Board fixed it for one of our customers. Savin First told us ok. Update Firmware, Do PM. We did .. No change.. Replaced Door Switches. NO change.. Finally replaced LD Board (yaknow tiny board on side of LD unit) And it fixed it.. All I can guess is toner on the board at one point shorted things out or the Tech Vaccummuning the machine vacced around that board. Yeah he admitted he did.. Vac, toner, boards = bad lolComment
ok
did clean ld unit w/o vacuum used air cannister.so i will rr ld unit got one on shelf.if it works you get pound of smoked salmon .Comment
As mentioned by TSC04 check the laser power settings on the smc report, if they are high, it is likely that the door switches near the fuser are full of toner and need replacement. Not hard to do and a cheap fix.sigpic
A+; Network +; PDI+Comment
Here is the bulletin for the 2045.( basically the same machine)Attached FilesNEVER ASSUME ANYTHINGComment
