constant error sc 387 yellow toner too lite. good fill will come back if do force toner so i dont thnk its developer ,cannot rely on counter dont thnk previos tech cleared them(pm and r counters)copies ok for awhile after force toner yellow,but sc comes back . have vacuumed out hose and pump working.
ricoh color 2238c
poor yellow
i'm with kopykat. if using "oem" toner is time to go back and replace dev unit (yellow) if drum unit is worn why not replace this too. these units are both vary reasonable compared 2 some iu's. make sure you "recalibrate "when u change them. there is a "sp procedure" for each!!
good luck!!
jpIT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
THAN TO SPEAK AND REMOVE ALL DOUBTComment
good luck!!
jpsigpic
Relax! This firmware injection won't hurt...but it will take 45 minutes.
fading yellow
Hey both you and the other post had it right!!! have never been trained on these bxs but see alot o dem. is mostly maint issues. pls remind me not to "borrow $20.00 from u!!! lol
tectwo
I'll put my money on the developer too. And don't forget to flog the other tech for not keeping up with the maintenance records - SOOOooo...CRITICAL to figure out what is wrong when one of these decides to go toes up with an oddball problem.73 DE W5SSJComment
I know some companies require techs to make notes on a sheet that is kept with the machine. Unfortunately we've had the sheet disappear too many time due to office employees wanting to read it or competitors getting their paws on it. So whats on the work order gets transferred to a database that is attached to the next work order next time a tech is out.Comment
