Aficio 2090
  • khalil792
    • Aug 2025
    Aficio 2090
    i update the system firmware in Aficio 2090 during updating machine power down when i trun it on showing error sc817 (0x00000004 ) please guide me how i overcome this problem
  • Eric1968
    • 2458
    I think the data on the SD-card is corrupt or damaged. Try to format the card, and try again. If this doesn't work, try another SD-card.
    The error 0x000004 means that the machine can't read/load the files on the SD-card.
    Good luck
    • khalil792
      Afico 2090
      i use same card to another machine its working and even new card i try but problem is still there
      • hosennet
        • Mar 2007
        • 145
        • KopyKat
          Nurse Ratched of Repair
          • Nov 2008
          • 365
          Let me get this straight....you lost power during the firmware update? If so you need to follow the instructions in Section 5-10 "Recovery After Power Loss" in your Service Manual. Probably going to need to order the Boot SD Card the part number is listed in that section.
          sigpic
          Relax! This firmware injection won't hurt...but it will take 45 minutes.
          • mrwho
            Major Asshole!
            • 4299
            Re: Aficio 2090
            Well, this happened to me right now on a 2075. Error code 817 and I'm stumped. Any tips?
            Mascan42
            Ibid
            • kyrenecopy
              • Apr 2012
              • 205
              Re: Aficio 2090
              B140/B141/B142/B143/B163/B228 SC 817 Monitor error - Replace system sd card
              B140/B141/B142/B143/B163/B228 SC 817 OS flash rom data defective see TSB 91R boot sd card
              Testing 1-2-3, testing, testing. Is this thing on?
              • Shadow1
                • Sep 2008
                • 1642
                Re: Aficio 2090
                Also be aware there are 2 different firmware levels for this machine Check the Tech bulletin:
                B070B071 %96 037R.pdf
                73 DE W5SSJ
                • mrwho
                  Major Asshole!
                  • 4299
                  Re: Aficio 2090
                  [ATTACH]16406[/ATTACH]
                  Thanks Shad, I'm talking about a 2075. Maybe I shouldn't have hijacked this thread.
                  I'll start a new one to avoid confusion.
                  Thanks for the tips so far.
                  Mascan42
                  Ibid
