Aficio 3111
  • tariq123
    • Jun 2009
    • 3
    Aficio 3111
    Can someone explain error code SC 541 of ricoh aficio 3111???
  • Eric1968
    • 2458
    I haven't heard of a Ricoh Aficio 3111, but SC541 is a thermistor error.
    • tariq123
      • Jun 2009
      • 3
      Re help
      Thanks for reply.
      Sorry it was 1113 not 3111 i wroted wrong.
      Thanks again.
      Eric can you explain after changing thermistor what to do i mean how to clear this massage SC541.
      Thanks once again and sorry for my stupid questions.
      • nmfaxman
        • 1702
        Reset it in service mode.
        • gernah
          • Jun 2009
          • 57
          SC541
          1 A Fusing thermostat/thermistor open
          The fusing temperature detected by the
          thermistor is below 10
          C for 5 seconds
          after the main power switch is turned
          on.
          Fusing thermostat defective or out of
          position
          Fusing thermistor defective or out of
          position
          Power supply board defective
          Sir the best thing you do clean the thermistor,check the thermostat and if you foun out that the thermostat is defective you drop in the floor so that the plate is going up again this temporary solution and reset the error you how to reset sir?press photo mode at the same time sharp sign.your problem is solve if you want to change thermostat is better.
          • gernah
            • Jun 2009
            • 57
            SC541
            C for 5 seconds
            on.
            position
            position
            • tariq123
              • Jun 2009
              • 3
              Aficio 1113
              Originally posted by gernah
              SC541
              C for 5 seconds
              on.
              position
              position
              Thanks for reply.
              You are right Sir, This is the problem of fusing thermistor.
              But now i want to know detailed method of reset process because i don't have service manual of this machine and have never worked before on it.
              Hope you will never mind and will describe the reset method with datail.
              Will be very thankful to you.
              Regards.
              • KopyKat
                Nurse Ratched of Repair
                • Nov 2008
                • 365
                Thanks for reply.
                But now i want to know detailed method of reset prosses because i don't have service manual of this machine and have never worked before on it.
                Hope you will never mind and will describe the reset method with datailed.
                Regards.
                If anyone posts the procedure to enter SP mode in the open forum here or in any other thread I see I will give then negative rep points. WORD!
                sigpic
                Relax! This firmware injection won't hurt...but it will take 45 minutes.
