RICOH 2232C fusing oil low
  • JJLTI
    • Jun 2009
    • 19
    Its really odd why I'm getting alot of Problems and calls about this printer RICOH 2232C.
    I just went to a site and they where getting an fusing oil low so, I changed it and replaced it with a brand new one.
    Now it keeps giving me the same error message that "fusing ioil is low" even when after I changed it.
    I have opened it and made sure the contact was clean and took it out, placed the unit back into the copier and still the same problem.
    not sure what else i should do, has anybody else have this issue
    thanks
  • Jomama46
    • 2900
    Fusing oil low is a counter thing. The new oil supply unit should have reset the counter and then blown a fuse unless the os unit was used or somehow the fuse was already blown. Try another unit. or change the spec in 7905-14.
    sigpic
    A+; Network +; PDI+
    • aabarnes1
      • Mar 2009
      • 620
      There is an sp setting for adding fuser oil called 'fuser oil add' butI cant remeber it off the top of my head.This will clear your error
      Grant me the serenity to accept the things I cannot change.
      • JJLTI
        • Jun 2009
        • 19
        So i should change out with a new fusing oil unit to see if it would go away? and how would i reset the counter?
        thanks
        JJ
        • Jomama46
          • 2900
          You dont reset the counter, the new os unit does. You can try 7904-10, that is the pm counter for os unit. I dont think it'll reset the message, only the pm counter. I think you have to replace the os.
          7905-14 allows you to reset the number of copies to make after the message and before it stops the machine.
          sigpic
          A+; Network +; PDI+
          • Jomama46
            • 2900
            You're thinking of the 1224c, it uses a bottle of oil.
            This machine uses an oil supply unit that comes with oil loaded.
            sigpic
            A+; Network +; PDI+
            • aabarnes1
              • Mar 2009
              • 620
              I stand corrected, my apologies.
              • JJLTI
                • Jun 2009
                • 19
                Thanks again JOMAMA46 !!!
                • devol-toni
                  • Jul 2009
                  • 3
                  Hello JJLTI,
                  For the "fusing oil low" message, you may try with this action:
                  In SP mode go to the SP -5-994-002 (Unit detection ON/OFF : Oil_Suply_Unit) and set to DISABLE.
                  Tray to print some job and after that you can set the same SP to ENABLE.
                  I think that this action will help you to solve the problem.
                  Regards
                  • kyoceran
                    • 100
                    check machine is resonably level, can result in numerous requests for oil units, check for traces of oil in lower parts of the machine
