how to reset mpc2500 print in single sided as default.
  • kayjaig
    • 144
    how to set mpc2500 print in single sided as default.
    right now it is printed on 2 one-sided to two-sided as default.
    i look up the setting could not find any 1 sided to 1 sided print setting
    please help.
  • Gary Bowen
    Bowdog
    • Mar 2008
    • 250
    Try the following:
    (1) Make the settings on the OCP that you want for your defaults (in this case turn off the 1 to 2, or 2 to 2 feature.
    (2) Select the PROGRAM Key.
    (3) Select the Program as Defaultsicon.
    (4) Select the Program icon.
    (5) Select the Yes icon.
    You should be good to go.
    • gernah
      • Jun 2009
      • 57
      please help.
      Sir,you follow this procedure:
      user tools
      document server
      input
      duplex priority 1 side to 1 side
      your problem its solve believe me or not.
      • Jomama46
        • 2900
        user tools
        document server
        input
        Sir: I do not believe you. They have not used that method for quite a while.
        Garys method will work.
        sigpic
        A+; Network +; PDI+
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          hehehe
          • Jomama46
            • 2900
            imind, I knew you'd be lurking around somewhere
            sigpic
            A+; Network +; PDI+
            • kayjaig
              • 144
              problem solved thanks
              Thanks for all.
              special thanks to Gary. he got the credit.
              • tcs04
                FORMER Techie
                • 1183
                Go Gary!!!
