2018 d printer scanner not working
  • Rick
    • Mar 2007
    • 277
    The printer & scanner button on this unit wont turn on . The printer button beeps twice but will not turn on . When I go to user tools it does not show that ther is this option on the machine . I removed the printer scanner board and re seated the connectors but its still the same . Any ideas any one ?
  • knobby
    • Oct 2008
    • 75
    May be getting confused with machines but i have had one of those where the sd card was in the wrong position or locked , cant quite remember but its worth a look
    Gaz
    • KopyKat
      Nurse Ratched of Repair
      • Nov 2008
      • 365
      In addition to the advice above....
      Sounds to me like you either don't have the required additional 128MB, its not seated correctly or is the wrong type memory. If this was a 'pull' from another machine did it work on the previous machine? Are you giving it plenty of time to boot?...those take a couple of minutes to initialize.
      sigpic
      Relax! This firmware injection won't hurt...but it will take 45 minutes.
      • Rick
        • Mar 2007
        • 277
        There was no 128 mem card in the slot. I will try that Thanks
        • KopyKat
          • Nov 2008
          • 365
          Glad to help!
          Ricoh print/scan units generally always require adding additional memory.
          sigpic
