Ricoh 2020D/Gestetner 620D
  • Vesigoth
    • Mar 2008
    • 133
    I can't get this machine to print out a fax confirmation. I've gone into the fax features and set switch 3 bit 0 to "1" and bit 5 to "1". I've also set switch 4 bit 7 to "1" so it will print a portion of the image that was faxed. The fax is being received at the other end just fine, but my machine won't print out the confirmation. Any thoughts or ideas would be appreciated. Thank you.
  • Patish
    • Aug 2008
    • 66
    Check the "Paper Tray Priority"
    Set switch 3 bit 2 to 1 (Automatic printing of the Memory Storage Report).
    Send fax through memory. It must print report before sending.
    • KopyKat
      Nurse Ratched of Repair
      • Nov 2008
      • 365
      Did you reboot the machine after the changes? Print a User Parameter Report to check the settings are correct.
      sigpic
      Relax! This firmware injection won't hurt...but it will take 45 minutes.
      • Jomama46
        • 2900
        If any of the Function keys (F1, F2 etc.) are programmed to print a confirmation report then that will override the auto confirm report you are trying to set.
        sigpic
        A+; Network +; PDI+
        • syamrock33
          hey bro...u need to press ok twice after u do the setting...
