Simplex mode MPC2500
  • kayjaig
    • 144
    For some reason, the MPC2500 is set to duplex mode in default. that piss off the users.
    How to set up in simplex as default. please advice.
  • nmfaxman
    • 1702
    User mode system settings.
    RTFB OP_Manual.
    • KopyKat
      Nurse Ratched of Repair
      • Nov 2008
      • 365
      MP series default screen setting...
      Programming Defaults in Initial Display
      This section describes how to program defaults for the initial display when modes are cleared or reset, or immediately after the operation switch is turned on.
      The default settings you can program are Color Mode, Paper Tray, Original Type, Density, Special Original, Original Orientation, Cover/Slip Sheet, Edit /Color, Dup./Combine/Series, Reduce / Enlarge, Finishing.
      • Specify scan settings and any other settings you require in the initial display
      • Press the {Program} key.
      • Press [Program as Defaults]
      • Press [Program].
      • When a confirmation dialog appears, press [Yes].
      • The current settings are programmed as defaults. The screen returns to the initial display.
      Note
      โ’ To restore the factory default settings on the initial display, press [Restore Factory Defaults].
      โ’ The default settings can be programmed separately for the normal screen and simplified screens.
      Same for all MP Series
      sigpic
      Relax! This firmware injection won't hurt...but it will take 45 minutes.
      • kayjaig
        • 144
        problem solved thanks
        thanks for all.
