Hello all. installed a mp161spf today and set up with a USB cable on a pc with Vista. Set up the print ok and installed a twain driver for scan also installed desk top lite as well but unable to see the scanner so unable to scan. Ive set these up before and everything has worked fine....any ideas ?????
MP161 SPF won't scan
I've never actually tried it but a crossover cable should work. Set Fixed IPs for both.
Edit" oops, Vulcor, you dog, you are too quick for me.sigpic
A+; Network +; PDI+Comment
Most newer NICs have the ability to "auto sense" whether the connection in the cable need to be crossed over or not.
So if you don't have a crossover cable handy, try it with a straight through first. If it fails, you won't damage anything.
Trying to find "ready made" crossover cables is getting harder and harder.
When you do find one, expect to pay considerably more for it.
Hopefully, you either already have one, or have the tools to make your own.
P.S...Cool avatar, Stig!“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
I'd really be surprised though if Savin/Ricohs were on that Autosensing Bandwagon. Not had too much luck with built in Mobo nics either.Comment
Sorry, I should have specified that I was referring to the NIC in the PC, not the MFP.
I know that the past few generations of Dell notebooks and desktops have had this ability. I'm sure that others have, as well. (We're pretty much an all-Dell shop.)
I have a Dell Latitude D610 notebook, and I stopped using a crossover some years ago. I carry one for emergencies, though.
In fact, the only time I have needed one in recent memory was to replace a bad one between a Fiery and MFP. Those must be crossovers.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
