check front cover switches above fuser especially if there is toner spilled in the machine. the fan above the fuser blows toner on these switches. also could be one of the three switches on lower left side of front cover
Sir,good day!I have incountered this kind of problem Im solve already,but im not sure if the same as your problem.Please check the continuity of each fuse in the power supply.goodluck!
