Ricoh 220 internal tray1 full
  • cosmic18
    • 19
    Hi guys please can anyone help me this old copier has locked out showing
    internal tray 1 full remove paper there is no paper there i cannot go into
    users tools please help
  • Ricohlovers
    • May 2009
    • 59
    Internal Tray 1 Full
    Hi.
    very common error, exit actuator for Internal tray. Pulled out the Lever (11) from PAPER EXIT.
    The paper overflow detection sensor [A] is located at the paper exit section of the fusing unit. When this sensor is activated, the machine detects that the paper stack height exceeded a certain limit and stops printing.
    Regards.
    • Vulkor
      • Jun 2009
      • 942
      If pulling the lever down to the proper position doesn't work Then the Paper Sensor arm has been pulled/knocked off its perch so to say. That requires removing the cover to that fusing unit. Front of machine. Small area. One Screw.
      • cosmic18
        • 19
        Thanxs very much for your help,the exit atcurator was dislodged i have not come across this fault before
        cheers
        • Vulkor
          • Jun 2009
          • 942
          Happens when tray gets full/or someone is rough...
          • garufa7x
            Re: Ricoh 220 internal tray1 full
            Thank you! I solved the problem. Greetings.
            • Masterchief
              • Apr 2011
              • 280
              Very old machine, lucky to have sorted this problem need i say that you might be called out again, better re order the part just in case to avoid fustrating call backs
              Masterchief
              sigpic
