Im having copy quality problem on an MP C2500 with less than 50k on the clock.
Copying seems fine, but when the customer Prints a photograph for example the quality is very washed out, its hard to explain but its not quite dense enough, almost like slightly damp paper (which is not the problem) .
Machine is fully serviced and calibrated, all test prints look fine.
I swaped another fuser unit into the machine and problem remains.
I disconnected the machine from the customers network and printed using my own laptop and a good crossover cable.
I removed the laser shutter.
I swapped over drum units.
All firmware is upgraded and up to date.
Returning tomorrrow to swap out the print controller from a working machine .
Any ideas?
Any ideas?
