Ricoh Aficio MP C4500 User Code Management
  • copyplus
    • Jul 2009
    • 100
    Re: authentication problem
    I just picked up a Ricoh MP C4500. When I try to change the IP address or any other function it says that you do not have the privilege to use this function. I tried to login with admin and blank password, 12345 password, xxxxx password, nothing worked, authentication failed. Would anyone help me to use the administrative functions of this machine. User authentication management under admin tool is off.
    • NeoMatrix
      Senior Tech.
      • 3513
      Re: Ricoh Aficio MP C4500 User Code Management
      Login in as supervisor and reset the administrator password.
      • copyplus
        • Jul 2009
        • 100
        Thank you very much. It did work. Now I am having problem to network this machine. I did set up IP address in the machine and in my router. When I send a print my computer communicate with the machine and tells me that the machine is low on toner but does no print. Any suggestions? thanks
        • NeoMatrix
          Senior Tech.
          • 3513
          #19
          Put in a new toner the machine, it should automatically restore the toner level an allow normal operation.
          You can disable the low toner detection in service/sp mode, but you will still require a new toner.
          Is there a print/scan SDcard installed in the machine ?
          • copyplus
            • Jul 2009
            • 100
            #20
            The cartridge is not 100% empty. It just shows low and the machine makes copies but only the print from the computer is not working. The machine has network, scan, fax and print options. thanks
            • NeoMatrix
              Senior Tech.
              • 3513
              #21
              I assume you have a working print scan SDcard in slot 1 or slot 2 (where the network cable plugs in)?
              I assume you have installed the required Ricoh printer driver on your PC.
              Can you ping the MFD?
              Example : Cmd.exe /k ping -a <ip-address>
              Can you login to the MFD through the WIM?
              Example : iexplorer http:// <mfd-ip-address>
              Can you post the IP address for the MFD and the IP address for the PC here to the forum, along with the subnet mask for both as well.
              Have you try connecting a crossover cable direct to you PC?
              • copyplus
                • Jul 2009
                • 100
                #22
                The ping command does work. It shows sent packages sent 4, received 4, lost 0 IP address for the PC 192.168.0.1 IP address is 192.168.0.166 for this machine = subnet mask 255.255.255.000 for both
                The test page goes to printer but is lost in the middle. I tried to install PCL 6, PCL5, universal drivers for windows 8.1 (x64), but none of them seems to work.
                With cross over cable direct to pc and after changing different drivers the test print shows in the printer menu box and the message says that the printer is offline. I did check the printer option on the machine and it shows online. When I install the cable back in the hub for my router the test page does not show in the printer menu box. I have almost hooked up 7/8 machine through my router and hub and they all work without any problem.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  #23
                  I get a funny feeling it may be a dead print-scan VM/SDcard but you should be getting error code sc867-2 or something like that.
                  [Network cables are set per normal modem/hub ]
                  Take the MFD off fixed IP address and set it to DHCP.
                  All subnet masks 255.255.255.0
                  1. Set the MFD to DHCP and see what IP,GATEWAY,DNS, displays in the configuration menu of the MFD.
                  2. Make sure the MFD: DHCP-SERVER , GATEWAY, DNS1 is the same as the settings as in the PC DOS screen <ipconfig /all>
                  • copyplus
                    • Jul 2009
                    • 100
                    #24
                    I tried everything. When I send a test print the printer status box in my computer shows offline whereas it is online on the machine. I have two similar machines C4500. I have the same problem on both the machines. I tried to replace the network cable. Put on DHCP. Turned the machine on and off. But still the same problem.
                      • 37494
                      #25
                      This thread is over six years old. Start a new thread if you really want to get help.
