Ricoh 4410L dev initialization
  • copyaction
    • Oct 2007
    • 991
    I had to put in a good used pcu for this unit but I would like to clear the replace pcu message.
    Is the a sim for dev initial. that would also reset the display?
  • Vulkor
    • Jun 2009
    • 946
    SP 7 909
    PCU Counter Reset
    1 Resets the developer counter.
    [0 = No / 1 = Yes]
    After selecting “1”, press the Halftone key and the OK key
    (or  key) at the same time to execute the reset. If the
    reset is successful, the display shows “Action completed.
    Or
    SP 5 912
    PCU Alarm
    -1 Alarm Display On/Off Selects whether or not the machine will display a “Replace
    PCU” warning when the PCU alarm counter reaches the
    interval set by SP912-2.
    [0 = Display / 1 = Do not display]
    -2 Interval Sets the PCU Alarm interval (count) at which a “Replace
    PCU” warning occurs.
    [1 ~ 255 / 45 / 1,000 sheets/step]
    • copyaction
      • Oct 2007
      • 991
      thank you
      • Vulkor
        • Jun 2009
        • 946
