Mericoh driving me nuts
  • ComputerMonkey
    • Sep 2008
    • 69
    ok ricohs standard mem card explored wont even install on my machine so any ideas/tips to make it behave? i click startup and nothing happens no error no window nothing
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Are you trying to install it on Vista?
    I sincerely doubt that it will work with the Vista OS.
    • neergish
      • 177
      we ditched Ricohs memory cards reader ages ago, we use "Elan Memory card explorer" works great (under XP at least). Allthough I seem to recall that there was some slight fiddling with assigning a reserved memory window.
      "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
      • zyqwiz
        • Jun 2009
        • 333
        There are 2 types of PCMCIA architecture - one works and the other doesn't!
