I got a full colored multi-functional Lanier copier i'm working with that are coming up with strange colored lines. Here's the thing. These lines only happen when i'm running 11x17 cardstock and they run from the top to bottom of the 11x17 page (If I run regular 11X17 paper these lines seem not to show up). Its usually only like 2 to 3 lines. This is on like a full color picture, and the color of the lines are different.. I see a faint yellow line, then a blue line, and then a red line. Most of the time its a blue solid line and a red line that breaks towards the midde of the page and reappears farther down. The distance between the 2 lines seem to be the width of a drum, but like i said they are different colors..
I inspected the drums really closely and I don't see any prominent lines which would have to be running the length of the drum instead of the usual direction. My best guess was the transfer belt which i changed out, but apparently wasn't the problem...
Whats weird like i said is that these lines only show up when you run cardstock through it and are usually on the latter end of the page of an 11x17 paper. So if I run 8 1/2x11 im good.
I'm thinking that unit that makes the color output is frying out. I forgot the name of that unit..
We are printing to the Color copier btw and having these issues. Any help would be much appreciated.
