Please hepl! aficio 470W printing error
  • anchor
    • Aug 2025
    Dear all
    Please help
    When printing a autocad file by Aficio 470W printer, if the drawing has a large amount of numbers, then the number 8 and 9 were fully filled by black color
    what's will I do ?
    Thank you
  • gaudin
    • Mar 2008
    • 39
    sounds like a problem with a driver. If its possible try to use PostScript.
    Certified for:
    Compita A+ / N+ / S+
    Microsoft MCST / MCA
    • Ralph S
      Originally posted by anchor
      Dear all
      Please help
      what's will I do ?
      Thank you
      More details are needed.
      Version of Plotbase software?
      Version of AutoCAD software?
      How is the plot file created? WinPrint? Plot to file and PlotClient? HDI Driver?
      • anchor
        where can I get driver, and software..as you say? Could you give me ? Thank you so much.
        • gaudin
          • Mar 2008
          • 39
          The PostScript-Module is an Option you must buy.
          If you print a config-page you see (somewhere in the first lines) the available printer-languages (sorry, dont know the exact word) like: PCL, PS (PostScript), RPCS...
          An if you see there PS you can download the drivers from Download | Ricoh Support Europe
          If you dont have PostScript try to use the latest version of PCL
          Certified for:
          • Ralph S
            470W.
            They are too large to send. All the software is on the Ricoh TSC web site.
            Technology Solutions Resource Center Website. More specifically, http://www.tscweb.net/tamrofediw/cw470.asp
            The software (Plotbase) is the Printer. The software is installed on a W2K or XP PC along with the proprietary board, and the cable connects the copier thru the printer expansion option on the 470W. The print drivers are then shared (WinPrint) off of the host PC. It is recommended that the PC not be a workstation used by others and is dedicated to the Plotbase SW.
            The path locally would be \\ <name_of_PC_hosting_Plotbase>\RW470W. Double click on that to ADD the printer to the users PC. There is a tools folder that contains the WinPrint driver, but it will ONLY install on the PC that has the Plotter control board on it.
            Plotbase is about 300-450 MB download iso file. The license to use the software is acquired thru www.rspfiles.com using the serial # off of the board in the host PC.
            I'm sorry that I cannot be more specific, but this is a 3rd party software licensed to Ricoh.
            • Ralph S
              I asked these questions for a reason. It is ALL very important to know so that your issue can be addressed.
              • anchor
                thanks for your help
                • thienphu
                  • Apr 2012
                  • 6
                  Re: Please hepl! aficio 470W printing error
                  Unfortunately, i am in Vietnam, how i can request a Ricoh ID to access and download files? anyone please send my links to download ricoh 470w printer controller plotbase?
                  • Shadow1
                    • Sep 2008
                    • 1642
                    Re: 470W.
                    ...and it has a nasty reputation.
                    I've seen all kinds of artifacts dropped into the output by older versions of PlotBase, and honestly, the new versions aren't much better. I have one customer who still cannot print PDF's he gets from some state contracts. He converts them to a TIFF and they print perfectly.
                    It's been a while since I've had to fool with this Piece Of Sh.. um... Software, but you may be be better off investing your time finding a workaround, since there may not be an answer. The newer Ricoh wide format machines use the same GW controller the copy machines use. Works much better. Scanning is usable on the GW controller as well.
                    73 DE W5SSJ
                    • thienphu
                      • Apr 2012
                      • 6
                      3rd party software ... i really can not understand how they work. I have sent email recently again and again but still no reply. Now my Ricoh 470w, missed features printing and scanning because of 3rd party software stopped supporting anymore?
                      sorry for my bad english.
                      • jdzr
                        • 125
                        You can get very little support from Ricoh as they no longer support this product. You can possible get some support directly from the software mfg. RATIO America, Inc. - Home
                        You may also be able to get some support from these guys. One of the individuals helped in the design or the software works for them. I have referrred several customer to them and had their problems resolved. I'm sure their service is not free but they may be able to help you. Ricoh RW-240W Plotbase 3.7.3 Upgrade with Win 7 Support [RW-240-UPGD-373PB] - $1,100.00 : J2 Blueprint Supply Co, Online Store
                        Good Luck
