I ordered one and it wasn't a special low price - I paid full price for it!
What's wrong with the touch screens?
That could be possible, as we've had our two days of summer here in the UK and I had one of these go. Makes ya think......Comment
Come to think of it now!!
I replaced all of mine in summer and had not yet replaced one this winter. hmmmmm?What? HuH?Comment
Hi Guys, I had a touch screen that nothing would responded so I pulled the touch screen connetor out an saw that the foil connector was dented in so I flatten the dent and put tape backing on the mylar that was changed on the tech bulletin and guess what it works. So my thinking is that there is nothing wrong with the touch panel itself just the mylar behind the foil connector that does not support the constant pressure from contacts on the foil connector. This might save a few bucks for the ones who have to pay for the touch panel, in the USA Ricoh has a no charge replacement so it doesn't cost us anything.Get your facts first, and then you can distort them as much as you please.Comment
Re: What's wrong with the touch screens?
Hi guys,
My MPC4500 touch screen responds only from middle to top part of it, bottom nothing. But the strange thing is that if I use some cleaning surface product over it, the same works also in the bottom part for some minutes, after stop responding.
What do you sugggest? Do I need to change it or I can do something to fix it..?
Thanks in advance,
FabrizioComment
Hi guys,
Thanks in advance,
FabrizioComment
Many thanks my friend!
Tomorrow I'll try to do it and I let you know.
Fingers crossed!
Thanks again,
Fabrizio
Perform a full touch screen calibration, Yellow 1993 Red x5. If it is still off, remove the operations panel, remove the back panel and boards, then careful remove the touch screen (take note of the ribbon cable, if the end is white it is a modified part, if it is brown it isn't; the brown ones are faulty) give it a clean. If it is clean and still does it, replace.Comment
The conductive compound between the ribbon cable and the touch panel detoriates by the time. Only solution is replacement. Densi has them for a good price. The Densi # is RHPT0002
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
yes it seem to work! Great!!
Many thanks,
;-)Comment
