ricoh ft5632
  • ron
    • May 2025
    ricoh ft5632
    Hello everyone. I'm just new to this site. I have a question regarding my old copier ricoh ft5632. I just changed the drum, but now it is too light when making a copy. I was told to change the developer as well, is that true? If so, how and where is it located? Thank you very much to all those who will respond.
  • YHEL23
    • Nov 2008
    • 146
    You can try 1st SP 2-207 to force toner. if still change developer.
    DYNAMIC OFFICE SOLUTIONS
    • ron
      Thank you. But I just bought the developer already, now I don't know where it's located and how to put the developer.
      • Eric1968
        • 2458
        If you change the drum/developer you need to make a few adjustments in the SP-mode. I you don't know how to do that, then don't try to replace the developer. You will only make things worse.
        • ron
          Is it ok just to replace the drum and add the developer?
          • ron
            Sorry for asking, but what is "SP 2-207" is this a toner?
            • Vulkor
              • Jun 2009
              • 942
              It is a Service Mode and if you are asking this you must need to call a Technician or You can Royally Wreck things in Service Mode.
              • JustManuals
                • Jan 2006
                • 9838
                I guess business is so good you all can help this guy do it himself?
                • KopyKat
                  Nurse Ratched of Repair
                  • Nov 2008
                  • 366
                  I know a very good and reasonably priced dealer in your area...check your PM
                  sigpic
                  Relax! This firmware injection won't hurt...but it will take 45 minutes.
