I may be a bit late in saying this, but the registration is looking out of time. As said before clean your ID sensors
clean your optics.
run 2111-3 then 2111-1
check 2194-10/11/12 they should all read 1
run 3011 Normal then 3011 Full Music
check 3011 and again they should all be 11111111 - if not refere to the service manual.
Then Run the ACC.
This should set your copy quailty back to spec and then you can trouble shoot if needed e.g. sp 2109/4417 etc.
clean your optics.
Then Run the ACC.
