RICHO AFICIO 2238c " SC389 " CODE ?
  • SOCPWB
    Hi, expert:
    Here is a message code "SC389" showed on Aficio 2238C.
    DO anyone know what's wrong with machine? is that a wrong with magenta or sensor problems?
    thanks a lot!!!
  • Eric1968
    • 2458
    The machine encountered an error for magenta during process control (Vk is out of range).
    The manual says the following :
    - Low toner density
    - Toner supply problems
    - Laser exposure problem
    - Image Transfer problem
    I would check the toner supply tubes for obstructions, and try a new magenta dv-unit.
    You can always check the process control result in SP3-975 (should be 1111).
    • SOCPWB
      thank you so much!!
