Hi, Ive been working on a faulty MPC2500 that is really faint on ALL colours. Even Black and White is bad. It dosnt matter wether its printing or copying The result is thee same - real faint to the point it can hardly be seen.
The SMC report reads all PCU's are under life, and the transfer cleaning unit was changed about a week ago. At first I thought this may be cleaning the image off the belt. When I stop it mid-process, the image looks perfect on the transfer belt.
I have read a lot about the firmware updates to correct the laser shutter - so I have updated the firmware and even removed the laser shutter altogether. Still no luck.
I believe it to be a problem with the paper transfer / seperation unit. I changed the roller, then the high voltage board feeding it, then I also changed the IOB board as this seems to be the controller on the electrical schematics.
Im starting to run out of ideas - Im sure its the transfer roller not geting the signal to take the toner off the transfer belt. When I run A3 thru and stop it mid way thru the fuser, the fused section is faint and the unfused part is just low density toner - the rest of the toner is left on the belt.
So any help would really be apreciated!
Scott.
Scott.
