AFICIO 1515MF
  • +ve charge
    • May 2008
    • 87
    AFICIO 1515MF
    Hi... I have 2 machines that will copy, print and fax. But they won't scan. These are being used as 'stand alone' units [not networked]. I have checked the past threads and all of them address a networked environment. Pls run me through the procedure to make this machines start scanning documents to PC. Even if it is from square one.
    It does seem like I have missed the basics....
    Pls Help!
  • Eric1968
    • 2458
    Do you want to use scan-to-email or scan-to-folder. Scan-to-folder requires the installation of ScanRouter. For scan-to-email you just fill in the IP-adres, Subnet Mask, Gateway, DNS-server, and Mail Server. Just try to read the supplied manuals on the CD's. It's not that difficult.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      There are two options but both are via a network connection, no scanning options for USB connectivity.
      TWAIN (Network)
      ScanRouter (Network)
      Should be easy enough to rig up something with a cross-over cable.
      [EDIT] Ok make that 3 options then, still a network connection is required.
      • Scott_Lewis
        • Mar 2007
        • 519
        Pls Help!
        Have you looked at the Scanner Reference guide?
        • +ve charge
          • May 2008
          • 87
          Hi..
          Appreciate the replies.
          First, I do not have the CD's supplied with the machine .
          Second, Both machines (AF151MF's) are connected to the computers using USB cables.
          Is this the problem??
          thanks again.
          • Eric1968
            • 2458
            The USB-connection is only for printing not for scanning. For scanning you can use the (network) Twain driver, or you could scan to email, or scan to folder using ScanRouter.
            • Iommanxman
              • Aug 2009
              • 180
              Don't forget that Scanrouter will only work over a network. Like Eric has said USB functionality on most MFP's in the range is for printing only.
              • aabarnes1
                • Mar 2009
                • 620
                The network TWAIN driver and scanrouter software can be downloaded from Ricoh Europe, or the TESSA website.
                Grant me the serenity to accept the things I cannot change.
                • +ve charge
                  • May 2008
                  • 87
                  Hi...
                  Appreciate all yr time and effort to reply this post. All of you have been really helpful. Thanks
                  • Scott_Lewis
                    • Mar 2007
                    • 519
                    All of the Af1515 manuals are available (in English) at
                    Ricoh-USA - Downloads
                    • Iommanxman
                      • Aug 2009
                      • 180
                      Ricoh Support
                      That is a great place to get all the ricoh downloads from Drivers to Scanrouter even desktopbinder.
                      • Scott_Lewis
                        • Mar 2007
                        • 519
                        Originally posted by Iommanxman
                        Ricoh Support
                        My browser can't find that server.
                        Is that a EU site?
                        • Iommanxman
                          • Aug 2009
                          • 180
                          What Browser are you using. I think the ricoh site is very picky and has to be Internet explorer to make some of the drop downs work. and yes it's Ricoh support Europe.
                          • Scott_Lewis
                            • Mar 2007
                            • 519
                            I'm using Firefox by choice, IE when I have to.
                            Turns out my internet was slowly crashing at that time. Got to a point I couldn't even continue using copytechnet a short while after I posted here.
                            Anyway, I found the site and even found the infamous TESSA page.
                            • Iommanxman
                              • Aug 2009
                              • 180
                              That would explain why it didn't work. I am the same. Firefox through and through and then IE when the site doesn't work with Firefox.
