Scan to Folder
  • wwaweru
    • Aug 2009
    • 25
    Scan to Folder
    Hi people I need some help on something; I want to be able to scan documents from a network scanner to a shared folder Scanned documents are in form of encrypted PDF and to be directly sent to a Active Directory sharing folder via LDAPS (LDAP over SSL), I will appreciate on any help on how to achieve this.
    Regards
  • Froota
    Field service tech.
    • 129
    Regards
    So...
    What do you need?
    • Jomama46
      • 2900
      Which scanner?
      sigpic
      A+; Network +; PDI+
      • aabarnes1
        • Mar 2009
        • 620
        Did you mention SSL? From what I can remember Ricoh machines and SSL do not mix at all.
        Grant me the serenity to accept the things I cannot change.
        • wwaweru
          • Aug 2009
          • 25
          I need to know which scanner is capable of doing all these without me having to get an encryption software or any Scan job routing software.
          • zyqwiz
            • Jun 2009
            • 333
            On the copiers, they do PDF as default and 'encrypted' is one of the scan options. Don't know about stand alone scanners as Ricoh UK do not sell them any longer.
