2232c not printing cyan
  • ash_572
    • Oct 2008
    • 523
    not printing cyan at all. its has a new pcu with new dev unit including the dec inside the unit. new dev clutch. laser glass is cleaned.
  • Polo-022
    • Sep 2007
    • 486
    Laser white ribbon cable, backwards. Reseat!
    • E Winter
      Or maybe the pcu/dv locking mechanism is skewed - in this case the unit has too much play and will loose the drive-connection. Had this a couple of times so far - I just bend the locking bar a bit like a "banana"
      • rthonpm
        • Aug 2007
        • 2859
        Close to what Jan suggested, try a thin piece of styrofoam against the lock bar and the developer unit. I used to have to do this for a couple machines in an old factory before the developer units were re-designed to keep from drifting forward.
        Also, did you remember to take out the packing shield from the dev unit? I know there have been a few times I've forgotten that at first...
