I need some thoughts on this. I have an account that has a 3260c scan to folder and they also use the doc server. Lately the scans are coming through as colored lines or bw lines nothing can be made out because there is no text or images just lines. I updated all the firmware problem goes away for 3 days then it's back, I took my laptop via crossover and same results. * I reflashed the firmware a 2nd time to see and same thing it did not last long so now I have the problem again. They do have documents stored in the doc server not sure if this info helps
Any idea what is causing this?
