replaceds scanner now cannot adjust registration about an inch off.tried all adjustments through sp no change o0r not enough to get image to specs anyone got an idea what the issue is?
1035 ricoh
What do you mean, "replaced scanner"? The whole scan unit?
What was the original problem?
How does the trimming area pattern look. It should always be adjusted first, then the scanner 4010. then doc 6001sigpic
A+; Network +; PDI+ -
never mind
i am turning this machine into scrap possible bent frame cannot adjust reg also light on df mode.nothing will correct i repeat nothing not even the old pull up on corner of scanner.junking this p.o.s.Comment
